wheisenburg
Independent Solar Consultant
I am having two issues with my Schneider that started a few months ago. One is that I am getting Overvoltage F49 faults and sometimes under voltage faults. I have a dual inverter setup, with three Orient Power wall mounted batteries. The faults always seem to be on the same inverter (inverter 1). When I look at my traces, there is another issue. Sometimes the SOC reading is dropping to 0% (no the batteries are not dead). It will stay there for a day or so and then come back up. Also, the DC voltage and current traces, seem to have random glitches even when the inverter is not running a charge cycle. The way I have it setup, the inverters top the batteries off about every three days. I tried at one point to use SOC to charge the batteries. It did not work well. The SOC reported to the inverters would be at 90 even though the batteries were nearly dead. I am using voltage driven charging now.
If I disconnect my main power, the inverters will kick in and run my house with no issues. The problem seems to only occur when in standby mode. It happens once or twice a month. Maybe I have a bad connection between my main DC bus bar in the Power Distribution Panel and the inverter. I am thinking I should put the system in bypass mode shut all the batteries down. Then clean and re-torque all the DC connections to the two inverters.
I am also wondering if the Insight Controller or the communication link to the batteries might be bad. It seems to work fine most of the time, but these F49 faults seem to happen when the SOC is now being read properly.
Any other ideas?
Any other ideas?
