monochromatic
- Oct 28, 2022
- 18
Hi, this is a follow-up to my previous post after learning a lot the past few days. Thanks to all who replied!
My goal is to make this as safe as possible, as I want to mount this in a closet in my house (maybe a bad idea?). Here is my design so far:
Does anything look wrong in my proposed setup?
My questions as listed in the image:
- The 1012LV-MS user manual says: "CAUTION!! Before connecting to AC input power source, please install a separate AC breaker between inverter and AC input power source. This will ensure the inverter can be securely disconnected during maintenance and fully protected from over current of AC input. The recommended spec of AC breaker is 10A for 1KVA, 20A for 2KVA, 32A for 3KVA, 40A for 4KVA and 50A for 5KVA." The 1012LV-MS will be plugged into a 20 amp GFCI outlet, so are they saying I need another 10 amp breaker before it plugs into this outlet? Very confusing for me.
- I've read all the threads about the MPP ground/neutral bond and yet... still don't seem to have a clear answer. Basically since this unit will be plugged into the outlet full-time, it can use the G-N bond at the main panel in my house. Do I need to short the dry contact ports to always use the main panel's ground neutral bond?
- The goal of this build is safety. I want to be able to leave my house for a week and not be concerned about the house burning down. All of the battery cables will be run in conduit as much as is feasible, I'm going to use a Class T fuse even though it might be overkill, etc. What would make this safer? I've thought about enclosing the entire setup in a metal utility closet with some fans, lined with drywall in case of an inverter or battery fire.
