I do not remember the amps that were pushing through yesterday but I never saw it higher than 10 or 11 that I recall. Also, I only have 8 fuel cells, not 16. They do not balance very evenly across the fuel cells and I have switched sides a few times to manually even it out. My understanding is that it will do that itself but I was a bit nervous and wanted to even it up.
I think I had set the charger incorrectly yesterday as the volts would keep increasing as it would charge. Somehow I had the amps constant. I set it to 3.5 last night when I went to bed and the volts per the charger was 3.63 when I woke up. I reread the manual and figured out how to keep the volts constant, other than some small variation up and down. Right now it seems to be pushing .30 amps only. The cell that has the charger reads 3.622 and the cell at the opposite end is 3.546.
My Overkill BMS and the capacity testers arrive this evening so hopefully I can get all charged and then hooked up and test it tomorrow or Sunday.
