henk_lifepo4
- Oct 31, 2021
- 16
Hi,
I am a newby to building batteries so excuse me if I ask a stupid question?
I have build a 4s2p battery off 8 220 Ah cells wih a JBD 150 A bms.Total capacity 440Ah. In rest the cells are within 10 mV. But now I see that one cell (so consisting off two "units" ) triggers the 2.5v low thresshold when I switch on the Nespresso which draws about 110 A peak.
1. Am I right that (at least) one off the cells probably is bad.
2. Can i identify the wrong cell by diasembling the original battery, top balancing all cells and reasembeling it into two seperate bateries each just 4s with one off the disbehaving cells Then when I start the Nespresso one should be ok and one should trigger the 2,5v low voltage setting?
3. Is there a better way to identify the wrong cell?
Kind regards
Henk.
Kind regards
Henk.
