Dave (Boog)
I recently built a 48v battery using 16 272ah Lishen cells. I finally got around to running a discharge test using my Growatt SPF 3000TL LVM-ES inverter with a 1600 watt heater as a load.
I let it run and monitored the cells on the JK BMS app. The test ended when just one of the cells, #5 caused a low voltage disconnect. The remaining cells had various voltage’s remaining but none close to cell #5. Cell #5 reached 2.722 volts and the highest cell voltage was #11 at 3.177 volts.
Any ideas on why this single cell #5 would have gotten so low compared to the others?
Just a weak cell? Any further tests I could do? Is there anyway to possibly save this cell and get it to be closer to the others or should I replace #5?
Any suggestions would be greatly appreciated.
