Boron
Hi Guys, being annually retentive, I have been puzzling over making connections between prismatics, using typically aluminium busbar links. This seems to be a retro step given that you mechanically bolt a bar between two cells constraining movement given the tendency to swell during the usage cycle (and delaminate causing loss of capacity over time - separate issue. The electrical connection between aluminium is a well known difficulty cos of the instant oxide insulation coating (and the reason electrolytics work btw. You have to use considerable force to break through this nano layer.
Using two AL surfaces to make contact seems to compound the issue. Some suggest a special metallic paste - does this work is it eg MIL spec approved or is it a scam?
However thinking out of the cell I got some kit to make a proper crimped ring terminal, a solid 8mm job looks good for at least 100A. Now I also acquired some SS grub screws to make a threaded stud - then I thought some 6mm2 solar cable will make a suitable FLEXIBLE link between cells - cheap enough and easy with my hydro crimper THEN lightbulb moment, some internal shakeproof SS washers to bite into the AL surface of the cells - which I will additionally protect with some Si grease. Good for 20 years? What do you think?
OBTW I will also enclose sensor wires in the crimps for cell volts
