I don't have a "bad" cell yet, just trying to understand what I'm signing up for with a "parallel first" 2P8S configuration as the cells age. Eventually one or more cells will develop problems. Is my understanding correct?
(a) If a cell develops an internal short-circuit (say a slow short with low current) then its partner parallel cell will tend to discharge into it, pushing current backwards through the bad cell and heating it up. The good cell's voltage will drop as it discharges. The BMS should identify low voltage in this cell pair. During balancing, this cell pair will take longer to raise up to the correct voltage. If the cell pair's low voltage is severe then the BMS would switch off the entire battery.
(b) Alternatively, internal connections could break within a cell raising its internal resistance. When the battery is being charged, its partner parallel cell will accept a greater current than the "bad" cell and get temporarily overcharged to a high voltage. Meanwhile the "bad" cell receives less current and gets undercharged. Once charging stops I guess this overcharged "good" cell will slowly discharge into its undercharged partner balancing the cell pair again. Eventually, repeated temporary overcharging would cause some kind of failure in the "good" cell - once the entire pair is "bad" I guess its high or low voltage will be picked up by the BMS and the entire battery would be disconnected.
(c) A cell could fail completely "open-circuit" with no current flowing through it at all - it's effectively removed from the battery. During charging and discharging, its "good" partner parallel cell would experience twice the current of other cells in the battery. The BMS is now monitoring the "good" cell alone in this cell pair. Its voltage would vary much more than other cells, prompting the BMS to disconnect the battery.
If I'm managing a battery with problems a, b or c, I can identify the problem cell-pair from the BMS info, either watching in real time during battery charging or from a data log. But how to find out which cell in the pair is "bad"? Bypass one cell* with an appropriate-length heavy-duty cable, see what happens over 12 hours, then do the same with the other cell? After finding the "bad" cell, how do I deal with it?
LiFePo4 -- Parallel or Not? - Page 2 - Cruisers & Sailing Forums
Originally Posted by mbartosch And this is a very important one. One of the things I have learned over time is that it may look very easy on paper, but it may be difficult to execute in limited and
www.cruisersforum.com
