undercrust
- Nov 7, 2022
- 18
Hello,
About to begin assembling a 12V pack right now with 4x EVE LF280K battery cells. This weekend's rabbit hole topic was fuses and master disconnects. After distilling a few dozen (hundred?) of previous comments, noting the excellent input of @John Frum in particular, I just wanted to check the following is true.
1a) For this 12V battery pack, an adequate and suitable main battery fuse would be a Blue Sea (or similarly high-quality) MRBF terminal block fuse, rated at 125% of the expected amp draw of the system. For example, on my system I expect to have a 120A JBD BMS, and the highest expected draw is a 1200W Giandel inverter. Therefore, after building in inverter inefficiency, a 150A MRBF terminal block fuse would be sufficient?
1b) Continuing on this thought, a similarly sized Class T fuse would be considered the best-in-class fuse option, but is not necessarily required for this battery bank at only 12V? Conversely, using a similarly rated ANL fuse is insufficient as it does not have a high enough AIC rating for even a 12V LiFePO4 battery dead short?
1c) A proper fuse on the main positive terminal of the 12V battery will not save my bacon if something causes a dead short between the positive and negative terminals of one of the individual component cells and therefore I should wrap the individual cell terminals / exposed metal on terminal bus bars in electrical tape or kapton tape? [Try as I might I couldn't find a clear answer to this one, it seems I'm seeing pictures of a lot of people's finished systems where they leave the individual cell terminals exposed so I'm wondering what I'm missing?]
2a) In wiring the master battery disconnect, I should place the master disconnect on the positive wire before the positive bus bar? I will also need to be aware of the solar charge controller or inverter capacitors maintaining system power even after I turn the master disconnect to the off position. This is a battery master disconnect only.
2b) It seems some people opt to skip the master disconnect and just disconnect the battery cables directly? I have seen this particularly on portable DIY battery builds, where the battery is being brought to and from an RV or teardrop trailer or fishing boat and hooked in as a 12V DC system power source, using either SAE or Anderson quick-connect plugs. This will also be my use case, so I'm wondering if I need a master disconnect at all?
Thanks as always in advance to the pros that haunt this forum to keep us newbies out of trouble.
