I'm just getting started on looking into a battery back up system to pair with generator and solar. How does one best guard against a battery fire? I see YouTubers putting battery server racks on the floor of a garage of basement. I just learned about the NEC 706, in which case the batteries have to be out of impact range of a vehicle- so that means high mount wall rack. It also stipulates 5/8" drywall required in a garage and integrated/networked smoke alarm system. Would that be enough to keep a server rack from burning down the house? I thought about outside storage or a little "battery shed" but I'm drawing a blank on how to efficiently keep it above freezing temperature being in New England.
I also see the NEC says if you have more than 20kw/hr of storage, you have to go to commercial standards? So a 5 battery SOK rack would be 25-ish, putting me into that category?
Normally I wouldn't worry too much about passing an inspection and just DIY wire it all up. But if I want to sell power back to the grid, doesn't everything have to be checked out by the power company?
