itech20
As many of you may know, the EG4 "Chargeverter" is a neat device that allows dirty power to quickly charge batteries.
Unfortunately, it is not UL listed, nor does it carry any other listing mark or testing assertion.
The short version of the question: Is there any scenario in which it can be integrated into a PV + storage system that must be inspected and comply with the NEC?
Having spent some time reading what I think are the relevant sections in the free online browser, I fear the answer is no. However, I'd value some confirmation from the knowledgeable crew here on the forums. (And apologies if this has been clearly answer elsewhere before. I've done a fair amount of searching and haven't found an ironclad answer.)
Some further digression:
It's made clear, in several places, that listing is not a global requirement of the NEC, but is explicitly required for various types of equipment.
The relevant entries in the 2023 code I've browsed online would seem to be either Article 706 - Energy Storage Systems or Article 480 - Stationary Standby Batteries. In fact, given the phrasing, it's almost certainly 706 that would be relevant, as it applies to systems intended for regular use rather than standby/emergency use.
Regardless, in each place, broadly, there seems to be a listing requirement.
480.3 Equipment. Storage batteries and battery management equipment shall be listed.
706.5 Listing. Energy storage systems shall be listed.
So, that's basically it, yeah? If you do an install and are going to be inspected somewhere that bases its code on the NEC, the unlisted Chargeverter cannot be part of your setup.
