Hello DIYers! I am new to the forum, having researched building my own solar/battery system. I've been looking at a lot of different products to get what works for my situation and was hoping for some advice/input from other experienced people.
TLDR at bottom.
First, a little about me:
I have been in the solar industry since 2014, shortly after graduating with a degree in Energy Management. I've done plenty of electrical work, including solar installs, upgrading electrical panels, etc. so I'm not shy around electricity or installing equipment.
Now, my situation:
I rent my house which makes it very difficult to add anything to it so anything I do needs to be easily and quickly removeable (putting holes in the roof, for example, is out of the question). I have a MSP with a 100A breaker that feeds my sub panel with all of my loads for the house. My 2 large loads are a 40 amp stoven & a 30 amp dryer (both 2 pole). Everything else is lights and plugs. My plan/goal is to intercept the feed at the MSP and install some sort of transfer switch/relay/anything else. Under no circumstances should solar/battery power be sent to the grid (and especially not during a grid outage). So I need a device between the MSP and sub panel to make that "break".
Looking at my utility bills, the typical high consumption day is about 35-40 kWh (and it's not everyday). Based on my calculations, that would require a 200Ah lithium battery & (3) 600ish watt - give or take 50 watts - solar panels. (I can source these at a local supplier I used to buy from when I worked at another solar company.) I have a small flat roof section between the garage roof and the house roof which is slightly south east facing that I plan to use with some sort of ballast system.
So here's my plan:
Source my solar panel of choice: (can I get away with just 3 from a technical standpoint? Will other BOS components have an issue with under voltage or anything else? - I don't want to add in more panels and keep racking up the budgetary cost if I don't have to).
Source my 200-300Ah battery: (probably Amazon, open to suggestions) - I know the typical suggestion is a few days of backup, but this isn't an off-grid system so I'm not worried about it. Is it advantageous for any reason to have multiple smaller ones (besides putting them in series to raise voltage)?
Source control device(s): I am agnostic to all-in-one or individual components, I just need something that fits my needs. I would be perfectly fine with the MOES 80 amp device given that the max my house will never use more than 80 amps (according to NEC 210.20) except the largest wire size MOES designed it for is a #6 which isn't even code compliant! I haven't checked my MSP yet, but I have at least a #4. There are other options out there, but there is usually a spec that doesn't work and I don't want to spend a couple thou- on just the BOS (I was really hoping to keep the whole project under that). I've seen dozens of these types of ATSs, but not sure how confident I am in them yet.
TLDR:
1. From a technical standpoint, can I get away with just (3) 600ish watt panel in a string or will I have other issues down the line with other BOS components?
2. Is it advantageous for any reason to have multiple smaller Ah batteries adding up to my total Ah needs (besides putting them in series to raise voltage)?
3. What device or system (either an all-in-one or a true transfer switch or something else) can transfer power between grid & site power rated for my 100A loads and will not under any circumstances send power back to the grid that can also handle 3 solar panels and a battery?
Thanks for your insight!
TLDR at bottom.
Now, my situation:
So here's my plan:
TLDR:
