Please tell me if there are glaring errors in my thinking.
EG4 6000XP to Reliance Protrans 2 10 circuit manual transfer switch with or without 30 amp L14-30 inlet? Drawing line load from an existing 240 outlet
to the inverter.
Primary goal is to have have storm backup until weather clears enough to run the inverter generator. Need to power 240 volt well pump for very brief periods. Secondary goal is to utilize the daily available solar from 16 100 watt panels to power freezers and refrigerator.
I am elderly, have some physical limitations and on fixed income so must be wise in my planning.
Currently own the 16 panel, and recently purchased the Eg4 inverter. Have the inverter generator with a 30 amp panel interlock breaker installed.
Would like to start with 1 rack mount batteries and later get a second, budget being the reason for not going to 2 right away.
Would probably go with AO lithium, Expert Power or Vatrer battery
Sadly, money is a consideration so I cannot afford to scrap what I have to start over. I would be most willing to get to my goals, if recommendations to accomplish this exist, that I have overlooked.
to the inverter.
