JamesRich
No friend doesn’t have the 12 volt ac he’s just read about them. He has a 19 foot camper so he doesn’t need much. My fifth wheel is 34 foot 305 sf. It has two ac units, a 15k main over the kitchen / living & a 13.5k over the front bedroom. They both blow into the same duct work so I can run either unit to cool the whole camper. The main will cool the camper by itself just runs more than with both on. When on 30 amp outlets I can only run one anyway. The largest 12 volt I found was 12k & way too expensive! I can buy more batteries for less money.Does your friend have one? Also, what size is his camper? Also yours?
I have a fifth wheel and a 12 volt AC would be impractical for 250 square feet. I’d need a 15k btu AC which if I could find an 12 volt inverter AC would probably pull 120 amps.
