I'm a bit surprised nobody has left any comments. Oh well, I hope at least someone is learning something from this journey. It's been a fairly all-encompassing project with regards to my time.
Anyway, I installed the Halo UltraGrip (HUG) mounts on my roof last weekend. I cut the rails as well and joined them together with BOSS splices. To note, I first used a metal chop saw and that was absolutely the loudest method possible, I found. Perhaps I had the wrong wheel on it. I figured the stock wheel would cut through. It did but I'm pretty sure I ruined my ears at certain frequencies. What am I going to do, stop cutting and go put in ear protection? What am I, some sissy? In any case, it was this:
After the ringing stopped, I unplugged that thing and instead used my band saw. Holy smokes, night and day difference. I used it while my son was napping and had no worries of waking him up. It actually cut instead of melting the aluminum. I just let the weight of my arm on the handle cut through the rails. Beautiful cuts, and WAY less material lost in cutting. I love this little thing, highly recommended. Great $100 investment for metal cutting:
In any case, the HUG attachments were fairly straightforward to install. Snap lines, find rafters, lag bolt them in. I used multiple tools to try to find the rafters. I even tried using a 'magnespot' tool, which is supposed to be the ultimate. I put the transmitter right next to a rafter in the attic, flush with the deck. Then went on the roof and used the locator. Drilled through. Missed the rafter. WTF? Went into the attic and I drilled almost directly between two rafters. WTF? So I don't know what is up, if I got a defective one or what. I'll be returning it because it's not cheap. End of the day, a standard stud finder and tape measure worked best. I covered up any mistake holes with SolarSeal 9000, which is an approved sealant by Ironridge. Maybe today I'll be able to get the rails up there, we'll see. That's it for now.
