Folks,
Just build a plywood battery box for my fifth wheel. There is a solid 1/2 inch of clearance between the plywood cover and terminals. As this box will be subject to some thumps and bumps on the road, I worry a little bit about inadvertent contact between a terminal and the cover. I was thinking of using flextape or similar on the cover as a just in case, I realize the plywood itself is not likely to short out, but this is a 12V 400AH battery bank so there is some juice there. I also want to use it as anti-chafe around the penetrations in the box where the 4/0 cables enter. On a general note, what are folks using to make antichafe pads etc? I was also thinking of perhaps cutting up silicon pot holders of cutting boards>
Any thoughts?
ANdy
Any thoughts?
ANdy
