gamerscircle
- Aug 7, 2022
- 25
Please excuse this crude attempt at illustrating my thought process.
The panels are 2 Hanwha Model: Q.Plus-L-G4.2 - 330 W Series Poly [the ISC is 9.54 & VOC is 46.81]
1.) If I want to work on the system and not have to keep disconnecting the solar panels, I got a 32a circuit breaker.
2.) The battery is a 100AH , so based on what I have read, I need a 100a fuse between the Positive busbar and the inverter? Or Battery and Positive busbar?
3.) If I was to add a battery monitoring shunt, that will go on the negative side? Before or after the bus bar?
4.) The panels will be about 40ft round trip to the charge controller, will 12 gauge wire be ok?
5.) The rest of the system will be on plywood on a wall in the garage. I am going to use 2 gauge wire everywhere else with the exception from the charge controller to the battery and from the charge controller to the circuit breaker where I plan on using 10 gauge.
This is my very first attempt at this , I know I am making some errors, what & where are they? My plans are to use this as a backup for power outages for keeping the frig and some led lights on in the house.
