Hi,
I tried searching the forums, but couldn't find an answer that made me comfortable.
I have a Renogy 600w solar kit with a 60A MPPT controller that I am installing on my travel trailer for a 12 volt system.
There are 6 x 100W panels with a short circuit current of 5.21A and Max series fuse rating of 15A.
The series wattage would exceed the max wattage for the controller, so I am configuring them in a Series/Parallel configuration of 3 panels each. That brings the max amperage for each series to 15.63A, exceeding the max fuse rating of a panel.
Since I am doing a Series/Parallel setup, would a single 15a fuse on the positive wire be enough? Or do I need a different fuse? I don't want to screw this up.
Thank you for taking the time.
-Mike
-Mike
