I’m on a 12v offgrid system with 400ah of batteries and a 2000w inverter. I have two systems. I’m upgrading one system to 24v with a 3000w inverter and the other system will be a 48v system 6500w inverter. I will be using 4/0 wire for all my new setups because I have a lot of extra cable. My question is do I fuse to the size of the inverter or do I size my fuse to the max amps of the wire (4/0).
So what size of fuse would you use between the 24v system with a 3000w inverter? Using the 4/0 wire.
