Alkaline
Solar Wizard
gotcha, thread title said 305...haha... cool, I wonder if they can square terminals like the rept cells for more area on these cells.
You should change the headline to 280Ah.I went with 280ah. Didn't have enough to do 305ah
It's fixed. Lol. I didn't even think about that.gotcha, thread title said 305...haha... cool, I wonder if they can square terminals like the rept cells for more area on these cells.
It was there. I reversed the wires going to usb adpter. Rule is don't wire when your tried. LolSolar assistant just put support in for JK BMS so you might need to update your installed version.
Just tried to buy a bunch of these st 18650 and they are basically out. Someone purchased a large amount right before I called lol. I ended up getting eve 230's. These will be better for me size wise anyway.Finally did a capacity test on my ganfeng batteries. From full to empty they pulled 290ah. Not to shabby.
How many were you trying to get. I only took 16 of them lol ?Just tried to buy a bunch of these st 18650 and they are basically out. Someone purchased a large amount right before I called lol. I ended up getting eve 230's. These will be better for me size wise anyway.
52. He told me there were only 16 left. Perhaps you got them ?How many were you trying to get. I only took 16 of them lol ?
That may be a safe assumption. That may also be consistent with the reports of quality coming from that vendor.I wonder if by 're-stocking' they were sorting through the ones they already had but that didn't test out above 280?
I don't know anything about Ganfeng cells. I was referring to good reports about 18650 store.Meaning Ganfeng is known for low quality cells?
I have some of these cells also. Some are marked 22-10-18 and some 22-10-19, so I'm pretty sure its year, month, day.Got these delivered already, took about 3 or 4 days after ordering from 18650. They are marked 284, 282, 281, and 279.8 in one box. The other box just has "280AH" on the label and the cells' individual labels are all 280.5-280.8 except the fourth one is 280.2, has the foil thing in the center of the top deformed, and has fluid soaking the top. I'm guessing this is some sort of rupture? Haven't had any extreme temperatures around here since it was dropped off, the cardboard box looks normal on the outside, and the cells were all securely in their shipping foam with the fluid contained around this one cell.
They all show 3.28V except the 284Ah one reads 3.25V, as does the leaky one.
What date format does Ganfeng use? Would these be from 2018 or 2022?
That is where the electrolyte vents if it needs to. I had one do that and it did not hurt the cell. You will know if it vented, because of the smell of ether.Could someone here explain what that silver foil thing on top of the cell is?
Should the vent return to the 'sealed' look of the others when done venting?That is where the electrolyte vents if it needs to. I had one do that and it did not hurt the cell. You will know if it vented, because of the smell of ether.
