chrisski
Solar Boondocker
- Aug 14, 2020
- 5,192
I would like to get the Aims Converter that Will recommends, the Aims 120 VAC to 12/24 VDC Converter model #CON120AC12/24VDC. This will be for an RV installation.
Can this be run by a 2300 watt continuous, 3000 watt peak inverter generator?
I see that this has a 15 amp plug, and needs to be connected to at least a 10 amp AC breaker, so I would think so. These converters do not have big motors that spin so I don't expect a large locked rotor amperage, but I don't want to be in a cloudy day and fire up my generator to replenish the batteries to find out that this won't work with an RV. 24 volts and 37.5 amps of charging is about as much as I'm going to get out of a 120 VAC converter before I need to go to 20 amps or make the jump to 240 VAC.
EDIT: For any others thinking of this, here is a link to the owners manual:
AC Converter / Battery Charger 12/24 VDC Smart Charger 75 Amps - Listed to UL 458/CSA
Get versatility, fast charging and a warranty with the AIMS 12V and 24V AC 75-Amp Converter/Battery Charger from AIMS Power.
www.aimscorp.net
