JBoffgrid2022
- Oct 28, 2022
- 153
Hello All,
I am relatively new to the solar field and have recently installed an off grid solar system at our camp in Maine. That being said, please excuse my ignorance here as I attempt to explain my issues and/or problems. I have had many problems diagnosing issues with my inverter and the latest problem I cannot seem to figure out which is why I have turned to you all in hopes that I can fix this issue. We purchased an off grid kit from Shopsolarkits.com (Complete Off-Grid Solar Kit - 6,000 Watt 24V Split Phase [120/240V] Output + 6 x 200 Watt Solar Panels | [OGK-10]) which they no longer sell otherwise I would post a link to the kit. Here are the complete list of products included:
1 x 6000 AIMS watt pure sine inverter charger- 24 volt / Split Phase [120/240V]
1 x Quick Disconnect Switch
1 x 60 amp AIMS MPPT solar charge controller
6 x 200 ah AIMS AGM deep cycle batteries
2 x Battery temperature sensor
1 x 300 amp inline fuse kit for battery to inverter
1 x 80 amp inline fuse kit for charge controller to battery
1 x AIMS Power LCD Remote Panel
I also purchased a 12k RES Kohler off grid generator powered by LP gas that was installed by an electrician that was not entirely familiar with Kohler. (My original electrician unfortunately died of brain cancer shortly after we started the project, very sad situation). The power cables are run from the generator directly to the inverter (AC Input Side) inside of our camp. Then it runs outside to a shutoff panel that has a 30amp breaker. From there, it goes back inside to our main panel that powers everything inside the camp. This breaker has a 100amp main breaker shut off.
My problem is all related to the inverter and how it interacts with the generator. Here is the link to the AIMS inverter to reference the following: https://www.aimscorp.net/documents/PICOGLF1-6W 4821.pdf
I have looked high and low on the internet forums and have not found much information that could help. I also contacted AIMS customer service which has been a complete joke, so no help in that regard. On the inverter there are five "DIP" switches that are currently set to the follow: SW1 0, SW2 0, SW3 0, SW4 1, SW5 1. I am pretty sure my problems lie with switch 5 which is currently set to "1" or battery priority. When the battery capacity drops below 35% it will send a signal to the generator to turn on. This works perfectly and the generator continues to charge the battery and carry the load of the panel simultaneously. The problem I am having is the generator charges fast until it reaches about 70-80% capacity then it struggles for hours to try and charge above this amount. I have adjusted the "charge current control switch" to several different positions (50%-100%) to see if that helps but it seems to never reach 100% battery capacity. In the cases that it does reach 100% with the help of the solar panel input, the inverter does not send a signal to the generator to shut off. I have to shut the inverter off completely to get the generator to turn off. The manual clearly says that it should do this on its' own but I haven't seen it yet. Ideally I want the generator to automatically turn on, charge the battery bank to 100%, and shut off. That was my goal from the start and it's been super frustrating to not have this feature.
Any help or input would be greatly appreciated, THANK YOU!!
