Hi Folks I am new here.
I want to supply a bitcoin miner with a hybrid inverter. The required power is around 4KWh. For this I want to add PVs and a hybrid inverse so that the power provided to the miners looks like the following configuration:
1. no power at all is coming from Solar array. In such case all power comes from the grid.
2. solar array generates all necessary power. In this case inverter choses to supply the miner only from the solar array (clearly it must have priority.)
3. solar array does not generate enough, it is somewhere in between 0KWh and < 4KWh. Here the inverter must be smart enough to take whatever provided from the solar and only the remaining from the wall (grid).
I do not want to add Batteris to this system.
Can such system be build? What min size for both PV and inverter ? the miner needs 2 inputs at 230V.
Which inverter is recommended and can you give me a schematic....
Thanks a lot.
Thanks a lot.
