kscessnadriver
I'm basically decided I want to go one of the variety of plastic tubs for ballasted ground mounts and have begun to ponder what to use for actual ballast. Obviously whatever you can get that's the cheapest per ton makes the most sense, which is usually going to be some sort of rock. Locally I can get a product called Duraberm, it's a slag product from the production of steel, for around $7/ton + delivery. It's much cheaper than gravel, I just wonder about any potential effects on the panels from potentially using ferrous materials right behind a solar panel. Is there any reason this would be a bad idea, or any other considerations?
