I'm installing 2 single-axis east-west sun-tracking ground mounts. I'm not sure if I should line up precisely with the property line or precisely east-west. It would look more uniform lining up with the property line but I don't know how much I lose by doing that. What would you do?
If you have room, set as far back from you're property line as is good. I'm in the city and put mine >4ft (required by city) plus enough for the neighboring fence (6ft tall) to avoid shadows at low winter sun angles. However, my neighbor didn't comply with 4ft and put a pool shade right up against the fence. This creates shadow for about 6 weeks / year at winter sun's lowest angle.
I could report him about the offset but during this 6 weeks it's mostly rainy so in truth I'm not loosing much and I don't want to start a feud with my neighbor. I have maybe a 50kwh loss over those 6 weeks on an overall 14.5kw PV array system. Another neighbor planted palm trees - and bit by bit, after 15yrs they are blocking our view quite nicely and would render the PV severely compromised in power output if they were not due west. Fortunately it's only another minor loss.
My point is - leave back further than you might originally think (if you have room) or consider what a neighbor might grow or build down the road and don't necessarily count on ordinances to shadow protect you're array. An array could work 30, 50yrs and if you don't ever have to fool with it in the future that's a good thing
Especially if your city has a limit on solar production, going for maximum results seems right. Consider you are providing a reference for true bearings that all who can see it may benefit.
