I'm attempting to design a single-axis east-west sun-tracking ground mount. I know it's better to just add more panels. I still want to pull this off. I'll be using a simple reliable slew drive and a $50 controller that monitors the wind strength and levels when high wind is detected. I'm using 32 Bluesun BSM550M10-72HBD (https://www.bluesunpv.com/uploadfile/downloads/BSM550M10-72HBD-USA.pdf) divided into 2 arrays. I'm utilizing 2 1/4" 14 gauge galvanized square tubing for the solar panel mounting frame. The panel frame will be mounted on what looks like the pipe that holds up a see-saw. The post pipes will be 5 - 4 1/2" OD galvanized hexagon pipe. The horizontal turning pipe will be a 2" OD pipe.
I'm brand new to this so any tips are much appreciated.
Thanks,
Greg
Thanks,
Greg
