Simpleone71
I've read the many grounding questions on the forum and my setup is either slightly different or I'm not sure I'm understanding it all correctly.
I have one main panel that provides power to my Victron Multiplus II. The grounding relay is enabled on the Victron MP2. I have my Victron MPPT connected on the grounding screw to my grounding bolt on the Victron MP2.
I am doing a 4 solar panels ground mounted setup. I have 8/2 MC from my MPPT to the solar panel array. Should I not use an 8 ft grounding rod by the solar panels to ground the array or should I use the ground wire in the 8/2 MC to ground the array back to the MPPT/Victron MP2?
