I'm setting up a system in the back of my Tacoma to power a fridge, USB recharging, and an inverter to power Starlink. The system is solar only (not tied to the alternator). Grounding questions:
1. All negatives run back to the negative bus - do I need to ground the negative bus to the chassis?
2. I'll ground the inverter (Victron Energy Phoenix Inverter 12/250) to the chassis directly, correct?
Anything else that I'm missing? Thanks!
