I'm planning to use a Growatt 3000 in my van build and I'm trying to figure out how to handle a low temperature charging cut-off. Can anyone with this unit answer the following questions?
Thanks
- Is it true that the mppt charger continues to operate even when the power switch is turned off?
- Does the AC to DC charger still operate when the power switch is off?
- Is there any reasonable way to disable the Growatt's charging functions (both AC-DC and mppt) without completely disconnecting it from the battery?
Thanks
