chrisstratton
- May 24, 2021
- 119
I’m doing an initial charge. I have a 24 V DIY battery. the Growatt all in one is set to the AGM battery type. In looking to change the Growatt battery type, when I attempt to set it to lithium it is not happy. I get a fault code LED. The Growatt instructions specify for the Li battery type that there is BMS communication. I believe that this is why it faults. I am guessing at BMS communication being the cause of the fault code, as I do not have a cable from my BMS on the UART port, and no Bluetooth dongle on the Growatt.If so, does this mean I have to define my own user type? If I do have to define my own battery type, does anyone have suggested settings? Thanks in advance. Chris
