Hello,
When I use my 10” compound mitre saw I am occasionally having an issue where the SOK battery seems to go into a protection state causing the Growatt to no longer see the battery and thus throw an error 52 “bus voltage too low”. I am guessing the bus voltage is too low because the battery completely disconnects itself. During these errors, The battery is at 75% or more capacity. Cells are balanced too.
If I turn off the PV array off and on to let the growatt reboot, it clears the error 52 and also the SOK battery kicks itself back in after something like 60 seconds.
The AC output on the inverter connects to a breaker panel with a single 15A breaker which feeds a receptacle. I use a 75’ extension cord to reach the mitre saw.
I run a fridge 24/7 and various other items including an electric kettle which has a high watt surge I believe. These do not use a long extension cord and they do not cause the error 52. In fact, nothing else has caused the error.
Any ideas?
Any ideas?
