Hi All,
I have a Growatt 5000ES which I have been running with a SOK 48V server rack battery (5kwh) quite happily for 6 months. I recently added a second identical SOK battery and i am now seeing some issues.
The batteries seem to sync up and communicate ok. They charge and discharge together although the state of charge can differ by over 10% at times. The problem arises when I charge my vehicle and it discharges the batteries all the way down to cut off and then utility takes over (a common usecase for me and one that has worked just fine in the past).
I have my growatt set up to stop using battery at 20% (and begin using again after solar charges back to 30%). Since i paralleled the two batteries everything looks ok as the batteries drain until the batteries hit around 30% charge and then they instantly both fall to 0% and alarms start triggering on both the battery and the inverter.
I did not make any changes to the growatt config when i installed the second battery. It is set to LI and program 52 (which is what the lady at SOK told me to set when i bought the first battery)
What's going on here?
