Hi All,
I have a Growatt 5000ES which I have been running with a SOK 48V server rack battery (5kwh) quite happily for 6 months. I recently added a second identical SOK battery and i am now seeing some issues. The batteries are frequently not balanced and both charge and discharge at different rates (maybe this is normal?) and can vary in their state of charge by 20%. The problems manifest by the new batteries SOC frequently completely collapsing during discharge and jumping from around 40% to 0% instantly and then the battery and inverter both panic.
I am unsure if this is a battery balancing issue or if the new battery is faulty. One question i have is why is the new batteries BMS allowing itself to drain below 20%? This has resulted in the FCC going from 105ah to 91ah, which i assume is permanent damage!
I want to try balancing the batteries properly first. I asked about this before and was told to use the following settings:
Disconnect all comm cables
Set 05 to USE
Set 12 to 48.1
Set 13 to 55.2
Set 19 to 55.2
Set 20 to 55.1
Set 21 to 48
However on the growatt i cannot seem to set 21 to anything above 46.1 (which is clearly way too low for low voltage disconnect). Any advice on why i cannot set this setting and also more generally what i should do here?
Thanks!
Set 05 to USE
Set 12 to 48.1
Set 13 to 55.2
Set 19 to 55.2
Set 20 to 55.1
Set 21 to 48
Thanks!
