DanET1983
We are off gird with solar and generator. We purchased the Growatt 5000 ES a few months ago, connected to 4 Renogy 200ah 12 volt batteries and it has been working fine until recently. This past week I've noticed that even with decent to good solar input 200-275 volt PV input, the LCD display was showing the system to be in Battery Mode and was not charging. I ran the generator quite a while yesterday and found that the batteries were still only at around 46 volts by nightfall, with a battery low voltage alarm in the middle of the night. I put the system in standby mode to shut things down until morning. Upon daylight at around 6:30am when solar was kicking in I turned the inverter back on and it began charging the batteries. I wasn't paying attention to the display, but several hours later realized that it was not charging the batteries anymore with the batteries only sitting at 45 volts.
I started the generator, yet it still was not charging the batteries (while solar was still in the 200volt or greater range). I went through the settings and adjusted a few items to try and see if I could get the system to start charging. By setting the Charger Source to both solar and utility it did temporarily show that it was charging the batteries but then that dropped off within 2 seconds and displayed only output from the batteries.
I am not getting any fault codes, but this sounds like there is an issue with a hardware component or maybe the software that is not allowing current to charge the battery? I doubt that the batteries would have powered our laptops and cell phones throughout the day so we must have been getting output direct from the solar panels earlier today.
Not sure what troubleshooting options I could try? Maybe just consider a different Inverter/charger unit and replace?
