System is 2 - 5000es inverters operating in parallel, 11 lifepower 4 batteries and one lifepowerLL that is operating as a dumb battery (no comm connection)
All the Lifepower4 batteries are connected for battery communication to the master inverter.
System working as expected for a while now. This morning at 2:20 am with the batteries at 85% SOC the inverters started importing from the grid and stopped using battery power for some reason. This should not happen until the batteries reach 25% SOC (setting in inverter).
As I'm writing this the PV arrays are starting to come up and they are contributing to the load but why did it switch to grid power in the first place with batteries at 85%?
Inverter priority is SBU or solar, then battery, then utility. No errors on the inverters. No alarms on the batteries. Inverters are reading battery voltage and have the LI indicator on meaning battery communication is present.
