Hello everyone. Excuse the inquiry that may sound stupid to some, but any help would be appreciated. I have an question that i cannot find the answer to in any of the manuals or anywhere online. I have 2 Growatt 5000es inverters that I purchased recently, that I want to use in single phase parallel mode. I also have a total of 16 x 600W solar panels to power these inverters. Considering that the maximum power input for each 5000es inverter is listed as 6000W, I would like to connect 10 x 600W panels on one inverter and 6 x 600W panels on the other inverter. The reason I want to do this instead of putting 8 X 600W Panels on each inverter, is that I will be adding 4 x 600W Panels in the future to have the maximum input for both inverters of 6000W each, but the location of the first 10 panels is not very accessible, so I want to maximize the input on that first inverter, and seal off the easy access to those first 10 panels, and then in the future I would be able to just add the new 4 X 600W panels to the second array (which already has 6 x 600W) and connect them to that second inverter.. is this possible, or do both inverters have to have the equal input from the solar panels to be able to be connected in parallel?
Thanks for the help
Thanks for the help
