My solar system has 2 Growatt grid tied inverters, a 6kw and a 10kw. They have been working flawlessly for 2 months, then yesterday, the 10kw inverter (model min 10000TL-xh-us) just stays stuck in standby. No faults showing. I've tried the things mentioned on this site, power cycling, changing startup delay to 301 sec, changing ramp to 600 on grid code, increasing voltage max by .1. None of these worked. I also removed the AFCI fault detection at Growatt's suggestion to get it working initially, and that worked, but now nothing seems to work. Any thoughts? The first inverter is working just fine, no issues with it.
