Hi All, hope you are well. Ive had a Growatt 5000ES installed since march. Everything is working well but the solar panels has been bothering me for some time now. A friend of mine has the same setup only differance is he has 12 panels i have 15.
Solar config or setup on mine:
5 x 435Watt Panels in series and 3 banks (Total 15 x 435Watt Panels)
This is what I get on the invertor: When i connect the first bank of panels (5 Panels) the inverter displays the total wattage approximately 1600 Watt. When I add a second bank the invertor displays approximately 3200 Watt. But when i add the 3rd bank it displays a maximum of 3595 watt. Regardless in what order i connect the 3 diiferant banks the findings is the same. Keep in mind this done on full load, i switched on the oven and some hot plates and the power drawn was about 5050watt on the AC side.
My friend with exactly the same setup only differants that he has 3 banks of 4 panels each. Also 435watt. The findings are exactly the same on his system just with slightly lower wattage readings.
I then started tesing and put 10 panels in series. I will then get 3250 watt on any 2 banks of 5 in series. In other words any combination of 2 banks in series gives me 3250 watt. This meaning that all my wiring and panels are working fine.
I dont know if anyone else has a similar setup to test with?
Thanks
Werner
Thanks
Werner
