SolarPowerUser2022
- Aug 27, 2022
- 5
Hello,
perhaps someone can help me. I bought the following Chinese LiFePO4 battery PS 5120E and I have the inverter Growatt SP2000. Currently, I get the following error in Growatt: "BMS COM fault". I did some research and I looked into the battery manual. The LAN cable is connected to the RS485 RJ45 port of Growatt and the other end is connected to the first RJ45 port of the RS485 section at the battery. At least this makes sense to me when I look at the table in the manual of the battery, where even the illustration seems to be wrong (there is no upside down RJ45 port):
![batterie_connection1.png batterie_connection1.png](https://diysolarforum.com/data/attachments/108/108948-db90d7302ccf883891e76f0893804a28.jpg)
This port seems to be the correct RS485 port and it's pins seems to be like this (the upside down illustration is wrong):
1 - RS485B 2
2 - RS485A 2
3 - GND
4 - NC
5 - NC
6 - GND
7- RS485A 2
8 - RS485B 2
![batterie_connection2.jpg batterie_connection2.jpg](https://diysolarforum.com/data/attachments/108/108949-b0d46bf1042b527f96f4c4190ab3cc40.jpg)
I have seen here, that Growatt uses typically the last pin of a RJ45 port for RS485B and the before last pin for RS485A. That means that a "standard" LAN cable should work with the selected RJ45 port on the battery which seems to have mirrored the PINs. In the Growatt SP2000 manual they use a "standard" LAN cable for the battery connection.
Because of frustration I even tried the other RJ45 ports on the battery. No success.
Perhaps you guys have an idea what I could try next?
Thank you and best regards!
1 - RS485B 2
2 - RS485A 2
3 - GND
4 - NC
5 - NC
6 - GND
7- RS485A 2
8 - RS485B 2
