I have Growatt SPF 3000TL LVM-24P and Blue Sea circuit breaker Panel and when I use shore power, everything works good, but when I disconnect shore power and use batteries, Reverse Polarity light is dimly lit and when I check the voltage I am getting 120V between hot and neutral, 150V between hot and ground and 150V between neutral and ground.
When I turn off the main circuit breaker on this panel, I am getting 60V reading between ground and neutral and 11V between ground and load. Neutral and load shows 0.4V. Any idea where I went wrong?
