GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 18, 2023 #1 So what it is doing is charging maximum of 60A. so let's say I have no solar I charge with 60 amps from the grid... but when I add solar let's say 700w. my grid charge will go down to 30A and get 30A from solar... I have max charge set to 140A
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 18, 2023 #2 Is the 3000tl actually capable of 140a of charging?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 18, 2023 #3 Just checked. 80a maximum charging capacity. Double check the settings. It appears that your setting is 60a.
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 18, 2023 #4 per owners manual timselectric said: Is the 3000tl actually capable of 140a of charging? Click to expand... Attachments 20230518_194534.jpg 138.9 KB · Views: 2
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 18, 2023 #5 timselectric said: Just checked. 80a maximum charging capacity. Double check the settings. It appears that your setting is 60a. Click to expand... 120a is 48v model 140a 24v .. these are my settings
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 18, 2023 #6 timselectric said: Just checked. 80a maximum charging capacity. Double check the settings. It appears that your setting is 60a. Click to expand... it won't even do 80A
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 18, 2023 #7 Check the settings on the units screen. To make sure that it matches Solar Assistant.
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 18, 2023 #8 timselectric said: Check the settings on the units screen. To make sure that it matches Solar Assistant. Click to expand... it does... I just checked before posting this
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 18, 2023 #9 Seems very odd. Have you tried changing the settings from the units screen, instead of from Solar Assistant?
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 19, 2023 #10 timselectric said: Seems very odd. Have you tried changing the settings from the units screen, instead of from Solar Assistant? Click to expand... yes.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 19, 2023 #11 Sounds like a firmware issue. If it won't take the settings. Unless the battery won't take any more charge.
GSXR1000 Solar Enthusiast Joined Nov 20, 2020 Messages 865 May 19, 2023 #12 timselectric said: Sounds like a firmware issue. If it won't take the settings. Unless the battery won't take any more charge. Click to expand... 280ah with 100amp bms and AC running so plenty of load... maybe firmware thank you
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,747 May 19, 2023 #13 GSXR1000 said: 280ah with 100amp bms and AC running so plenty of load... maybe firmware thank you Click to expand... Hopefully it's that simple. Good luck, and please let us know if that fixes it.
