When you look at the Data specs of the DVM vs. the DVM MVP - The only differernce is the MVP model can handle up to 245VDC Mppt Range vs. the DVM model has a Max of 145VDC Mppt range, in other words higher voltage input from your PV solar array. and the MVP is about 1/2% ,half percent less efficent.. That is the Only difference
