I think you’ll be surprised. I have installed a REC on a 600ah pack and it’s doing fine.
The current needs to taper when balancing, it doesn’t take much to reach 55°C then it cuts charging.
If your cells need more balancing, install cooling (a fan) on the REC module.
Doesn't seem to be working.
No cell has gone over 4.055 when charging at high amps, and the BMS is already ramping down at 61.60hz. It is only allowing 40% of the available solar power to charge the battery.
Per the instructions:
When any cell reaches the voltage interval between Balance Voltages Start and Balance Voltage End, the charging current starts to ramp down to 1.1 A x Number of Devices until the last cell rises to the End of Charge Voltage
But that's NOT what's happening. It is ramping down as soon as it gets within 100 mV of the END OF CHARGING setting. No cell has reached the 4.1 volt (Balance Voltage Start) setting, or has come closer than 4.055. I know because I'm sitting here staring at it.
As I'm typing this, it has now increased to 61.65hz, charging amps reduced to 19.5 amps, highest cell at 4.032
UPDATE: Now at 61.69hz with the highest cell still at 4.032.
The BMS is not waiting to reach BALANCE VOLTAGE START to begin its ramping down of the charge current. And I can predict, by past behavior, that by the time the first cells reaches 4.08 volts, the frequency will be up in the 61.90hz range, and it will only allow 3 to 5 amps of charge. By the time the highest cell reaches 4.1 volts, which it probably never will, the sun will be going down.
And this all assumes house loads stay steady. If someone turns on a vacuum cleaner or something, it will get even worse and possibly even go backwards.
I'm going to let it continue and see what happens, but it seem to be behaving exactly the same as yesterday. Gets within 100mv of Balance Voltage Start, then starts ramping down the current. It almost seems to follow the Inverse Square Law where twice as close = four times the attenuation.
Currently at 61.76 hz and trickling 9.07 amps into the battery with the highest cell being 4.032 volts. At that rate, the highest cell will never get to 4.1 before the sun goes down, and the lowest cell will be 10 to 15mV behind that one. My SOC and Coulomb counters will never reset.
