To clarify my needs, we have an irrigation controller that needs 24VAC. All the internal electrics in it are DC, they normally run on a 24VAC walwart and that power is what is switched and sent into the field to run solenoids and they are not rated for DC operation. I would like to have this controller as a stand alone without grid power, so I am trying to decide how I want to approach it. If I can provide 24VAC to the controller, I can just hard wire it and it's done, but I would have to install a small battery to run the inverter at night, or I guess I could rely on the DC back up battery (9V) for that, but holding constant 24VAC might be simple and reliable.
Other option is I could use a 120VAC inverter and then use the walwart on it.
The way these work is the internal clock and circuit works as normal with just the 9V battery, but without a 24VAC source, it just has no power to a switch to send to the field to power valves.
