How critical is the gap between the bolt and the hole in the lug?
I’m in the process of upgrading our camper from a single wet cell to a 300 ah battery bank. I drilled the Lynx pos & neg feeds to directly connect the disconnect and monitor to the Lynx however I first used a 3/8” bit which was too small so enlarged with a step bit to 7/16” that wobbled a little. How tight a fit should there be between the bolt of the disconnect and monitor and the holes I drilled in the Lynx? I really don’t want to burn us or system components up, how big a problem have I made? And if it’s big enough what are the recommended solutions?
