I've got 8 280ah eve cells connected in parallel. They all came at 3.27volts, so after getting them connected I hooked them up to a 10amp lab DC charger set to 3.65. Important to note that I was only getting 10 watts initially and it's been hovering around 30 watts ever since I crimped some 8ga cables on. It took them maybe three days to get to 3.31 (resting), and now roughly 5 days of charging (not non-stop, as I'm off grid and have to charge them when i am able) later, it's still reading 3.31 at rest. I've read that the voltage can sometimes appear stuck around 3.35 for a while when it is in fact charging fine, but the results I'm getting appear to be significantly slower than what is typical given a total charge time of around 8 days with no end on sight.
I disconnected all the cells and measured them individually and got the following:
3.31
3.31
3.31
3.31
3.28
3.30
3.32
3.32
So currently I'm charging the one that was still at 3.28 individually to see if bringing it closer to parity with the other cells will improve the situation. But is it normal for that cell to have fallen so far out of balance? They were disconnected from charge for about a day before this reading. Currently the one low cell is charging at a nice round 36 watts.
Any insights? Do I just need more patience?
3.31
3.31
3.31
3.31
3.28
3.30
3.32
3.32
