Hello, i have many plans for solar and power. I have an engineering background and am pretty handy. I just built my garage, and had the trusses engineered to take 6000lb of solar panels, but I want to start small first.
First, I'm going to build a trellis off my back porch that I want to hold 15 200w panels, 3 rows of 5, with the potential to add another 2 rows later. I want to tie it into the panel with a grid tie inverter. Then I have roof space with room for another 25 panels down the line. My question is, if there is no grid power, ie the power goes out, does the inverter shut off and stop providing power?
Second question is finding a grid tie inverter that is ~50a 220v, 2 110v 180 degree's out of phase, or roughly 10kw, so I can grow the porch panel array over time. This would go in my basement, but I also want a second one to go in the garage eventually when I put the panels on the roof of the garage.
Third, I also want to add a bank of batteries, I want the solar panels to charge the batteries, but don't want the batteries to supply power to the inverter unless the grid goes down. I realize that 10kw power flow is considerable from a battery, so I'm not sure what technology I want to go with or it's capacity, it's changing rapidly and I haven't kept up.
Forth, I want to build it myself, and I don't want it online. There's 2 reasons for this. Cost is a big one, but also the ability to change whatever I want to suit my needs without having to go with proprietary equipment. I want the ability to mix and match.
I can build and wire anything. I'm well versed in dc and ac power. I can run cable and build buildings, structures, and towers. I have all the equipment and tools necessary to do so as well.
Here's my current brain logic, if I'm wrong please correct me: Are panels wired in series or parallel? I'm guessing series, so that would make 10 200w panels producing 12v wired in series would be 120v dc at 16.6a, fed into an inverter. But a 10kw inverter I'm looking at says max input 500v dc. With 200w panels producing 12v, I would need 50 panels to produce 10kw, but that would be 600v dc.
Also, where are some good places to buy affordable inverters? From what I'm looking at 200w panels seem to be hovering around $100. But 320w panels are coming down a bit. Can I mix and match in series? It's just dc voltage, that shouldn't be a problem right?
Edit: I just realized I can do panels in series and in parallel. So 5 panels in parallel makes 1000w and 12v, then in series with 4 other sets of 5 wired in parallel makes 48v instead of 20 panels in series making 240v. I think.
