bluegoatwoods
I have now built two battery/inverter systems of 2000 Watts each. I'll start buying solar panels next. The purpose of the two power stations is mostly kitchen appliances. Of course they'll also power lights in case of power failure on the grid. That's one of the big reasons I've built them.
Another reason is that my wife and I might just choose to do some downsizing. We're already pretty tiny. Our home is modest. But now that the kids have grown and set up on their own, it's more home than we need and wish to maintain. I also don't really want to pay real estate taxes anymore. And I kinda don't want to pay the rather steep costs of being hooked up to the grid before consuming even 1 kw/hr of electricity. I'm not wildly ideological about these things. They just stick in my craw a bit. So it's possible that we could become nomads. Probably not, I suppose. We're aging and time is growing short for that. But if we decide to "bug out" I want to be ready. In fact, if this place............pleaassse NO...............burns down or gets wiped out by a tornado I'm not going to rebuild the conventional way. We'll regard the decision to downsize for real to have been made for us. Plus....we are considering wintering in the desert south-west in the future in order to escape the darned ice and snow. My wife, for that matter, seems to be very enthusiastic for this and might be disappointed if I don't take her there this coming winter. I can still see reasons that it might not be practical. But I'm friendly to the concept and do hope to do it sooner or later. I'd better make it sooner.
So I need off-grid capabilities.
I started with a 2000 W inverter and two standard lead/acid automotive type batteries in parallel. The batteries are on the patio just behind the kitchen. I bought a long and heavy duty set of jumper cables to feed through the wall and floor down to the basement and the inverter went there. This is a 'modified sine wave' inverter and does not seem to power a microwave very well at all. But I've not even yet managed to squeeze very much Wattage out of those batteries and this might have something to do with unsatisfactory microwave oven performance. The cables are certainly stout. Those conductors are nearing a half inch in diameter. The run might be fifteen feet. The connections to the inverter feed are mechanically stout. Though they might not be electrically great. About an inch of exposed cable is hose clamped to a spike of about 5/16 inch diameter. Presumably steel. They were painted. But I wire brushed the paint off. I drove the spikes through a 1 x 2 to keep them from ever touching. Two stout alligator clamps from each pole of the inverter clamp onto the other end of the spike. I add that detail in case anyone can spot some clear flaw which I've overlooked. The microwave made an awful sound when powered up by this and I gave that up immediately. This setup certainly powered lights. And it powered hand drills, random orbital sanders and my modest drill press well enough. Though I could sense that it was all a bit weak. I don't think I ever squeezed more than 1000 W out of it. I should have thought to check that with a clamp meter. I have also used "Kill-A-Watt" type meters at times. Handy gadgets. I especially like the ability to measure total electricity use over a specified time in a circuit with varying loads. Yet they seem to have a very high failure rate. I don't think I want to rely on them in the future if I must regard them as a quickly consumed resource. If I can only get two or three tests out of one before it goes blank or gives nonsense numbers, they they cost too much for their usefulness. My track record so far is not that bad. But it's not a whole lot better. I have ridden on this system for a couple of years now, regarding it as a source of light and small electrical loads in case of grid blackout. But I've kinda neglected to keep a close eye on the batteries. I know I've allowed them to discharge and sit that way. I haven't really paid enough attention. I've only needed it once in this time for an overnight power failure. And it did the job. With this plus a 2000 Watt gasoline generator, I have felt that I'll probably have enough power for a day or so in any other blackouts. Cooking? No. But I've got a few propane camp stoves which would get us by for short periods.
Eventually I bought a 12 V/100 Amp/hr life po4 battery. About a year ago. During this time it has set around only doing small jobs. Occasionally powering a 12 V tire inflator, for instance. But a couple of weeks ago I set it up with the inverter and started playing around with kitchen appliances. It operates a standard drip coffee maker, small air fryer, electric hot plate/burner just fine. The other day I ran a toaster oven at 375 deg on it for an hour. That nearly depleted a full charge. So I guess I gotta regard toaster ovens as being a bit too power hungry. But if I can build the capacity, then it'll find some use. For a few tasks it is just the right thing. This setup has only been in use now for a couple of days. I'm still getting accustomed the "reading" the charger and the charge on the battery with any confidence. And I've found it awkward to get all of our cooking onto this unit. When the main/stove oven plus a few other things are still powered off the grid, it is difficult to test our actual power usage using this rig. But I've got some rough figures together. It looks like a full charge delivers about 3/4 kwhr before undervoltage shuts down the inverter. This would seem to make sense since...........correct me if I'm wrong here, please................a 12v/100 Amhr battery ought to deliver about 1 kw/hr in one cycle. Ideally, that is. Once you take inevitable losses into account, I'd be happy with .9 or even .8 kwhr. .75 seems believable, if only a bit disappointing. But it still could be that I'm merely inaccurate and the real figure is somewhere around 90% or so. That would be fine. So I'm in the testing and "acquainting" stage of this setup. I'm not displeased with it's performance and feel confident that it's manageable.
