HELP! Growatt 3000TL LVM-24P in van.. want to use 12v... how to wire??
big spring
Hi, I am adding the Growatt 3000TL LVM-24P in a van conversion but I found it is difficult to add 12v for the applications in the van. Could anyone get me a guide to wire? Thanks!
Well for starters you will need a 24 to 12 volt buck converter.
Do you have a system diagram to share with us so that we may better understand your setup?
Hi, thank you very much for your response. Attached is the diagram. Please correct it. Thank again!!
Looks good, should be a fuse between the inverter/charger and the busbar.
Also a fuse between the buck converter and the busbar.
And a fuse block with fuses between the buck converter and the loads.
