Jack Mmkay
- Feb 22, 2021
- 17
I have a blueti eb3a. It has 268wh, which is nice.
I have two 100W renogy solar panels on my van's roof.
I'd like to purchase a 50 or 100 AH lifepo4 as a battery expansion for it. Id use it through the bluetti and Ideally id like to also charge it with solar trough the blueti.
It may be not the most eficient way as im deteriorating two batteries at once, but it gets the job done and it would be a long time until i need to replace anything.
What cables would i need to purchase / Frankenstein?
Is it possible to charge the external lifepo4 through one of the 12v barrel plugs? And If I wanted to use it I'd plug it into the solar socket? ( probably at night when there's no solar)
How would you do it? Do you have a better idea? Cheers from Spain
