jculina2012
Hey guys i have deye 12kw 3 phase hybrid inverter 48v battery model . i have gokwh 48v 100ah battery , this is battery link from aliexpress it says that it supports deye : https://www.aliexpress.com/item/100...param-url=scene:search|query_from:#nav-review
i have both lan cable that came with battery for communication and i have custom made rs 485 cable with pin 1 and 2 on battery and pin 7 and 8 on inverter. this battery allows to select inverter settings through battery main screen here is video i posted on youtube :
i dont know do i need to plug lan cable and use can port on battery or to plug rs 485 cable with pins 1 and 2 on battery and 7 and 8 on inverter.
which cable to use rs485 or lan cable, where on battery to plug this cable ? and which lithium mode to select in inverter settings ? i find this battery setup hardest from everything i did so far, insalling ground mount , panels and electrical installation and something that should be straitgh foward with battery i cannot establish communication. this gokwh 48v 100ah battery offers on its screen to select some protocols : there is deye rs 485 on the list there is deye can on the list , there is pylon tech also on the list. then confusing thing is when i contacted seller that sold me this battery he is telling me to select pylon can on battery screen as protocol. so i dont know what to do and what to select, can somebody help ?
